jmayo
Message 11 of 15 (891 Views)
Re: Moving profile or alignment,
10-18-2012 08:22 AM in reply to: JamaL9722060
You may also want to note that given a profile created with the Layout tools you can select the profile and hit the Geomerty Editor button on the contextual Ribbon tab you will see the Profile Layout Toolstoolbar. This toolbar has a button to raise/lower the profile. I can do all PI's or PI's within a station range.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
JamaL9722060
Message 12 of 15 (880 Views)
10-18-2012 01:05 PM in reply to: jmayo
Apologies for the confusion.
Yes, that problem occurs as I move the “profile view” but not the “design vertical curve”
I tried the “region” but has no effect!
When the “design vertical curve” disappears as I moved the “profile view”?
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
AllenJessup
Message 13 of 15 (877 Views)
10-18-2012 01:09 PM in reply to: JamaL9722060
I see what's happening but I can't reproduce it in 2012, So that may be a new "Feature Enhancement" in 2013. I'd suggest starting a Service Request if your on Subscription or calling them if you at gold level.
Allen
JamaL9722060
Message 14 of 15 (857 Views)
10-19-2012 10:23 AM in reply to: AllenJessup
Many thanks AllenJessup. I’ll see if it works
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
Active Member
RFrecka
Message 15 of 15 (402 Views)
10-22-2014 08:20 AM in reply to: JamaL9722060
Did you ever find a solution to this problem?
I've recently come across the same problem in a drawing of mine.
Surveyors input data and did profile work but it was put into local coordinates rather then world UTM as we require for the complete package. So my task is to copy the objects over, which is simple enough on its own, and then move them to meet the rest of the project. When I move them I seem to lose the profile data while the rest seems to have moved with all of its relative information intact.
