there are some points in my dwg that I can't move. I can rotate but not move. I noticed in the point file the ones that I can't move have a grey square in the cell with the point number and the ones I can move have an empty circle. How do I change the square to a circle?
Solved by Jeff_M. Go to Solution.
and in another dwg that I am xrefing (not binding because it either won't bind it or it exits the prorgams) into this dwg I have the pencil with the red circle. What are the ways to make a point, point style, or point group uneditable? Nothing is locked.
Can you attach a screen capture that shows the scenario you're talking about?
this dwg is from an outside source and has been drawn by different people using different styles using different layers using different...well you get the pic.
