Civil 3D Forum
moving pipe or structure from one network to another
26 REPLIES 26
Message 1 of 27
18243 Views, 26 Replies
what is the best way to move pipe or structure from one network to another?
26 REPLIES 26
Message 2 of 27
delete it from the one and add it to the other.
draw vanilla autocad construction lines first so that you don't lose the positional data.
Dan
Message 3 of 27
You can search this NG for a work-a-round. It may have been from
ChristopherF. It works something like this:
1. Land XML out the pipe/structures you want to move over.
2. Delete from your drawing these "LandXML" items and their network.
3. Rename the existing network to the same name as the one you just
deleted.
4. Import the LandXML back in.
I have not had a reason to try this, but it makes sense.
Bill
wrote in message news:5995301@discussion.autodesk.com...
Message 4 of 27
solovjev
The general idea is:
1. Export network to xml file.
2. Delete (Erase) features to be moved from drawing.
2. open file in any text editor. Erase all features not to be moved. Search/replace "old name" to "new name" for features to be moved.
3. Import edited file back to drawing.
Message 5 of 27
I guess there is a reason for two number 2's.
"Erase all features not to be moved." Why? If only the "one" network was
LandXML (ed) out. What is left to erase?
Bill
wrote in message news:5995788@discussion.autodesk.com...
Message 6 of 27
thanks
i'll give it a try
seems like a lot of work
maybe we should add to the wish list to be able to right click and swap networks (like you can do with parts)
also does anyone know any way to disconnect a lable from a structure (in 2007)
i would like to be able to label a structure then drag it to the side without a leader (to use as a structure table)
thanks so much for the ideas
lgs663
Message 7 of 27
solovjev
Two 2s by mistake.
I meant, you can't export/import particular pipe/structure. If you left "features not to be moved" in xml file, they will be imported and you will have doubled structures and pipes.
Message 8 of 27
solovjev
Create new style and turn OFF leader visibility in dragged state
Message 9 of 27
that would be perfect
can you do that in 2007?
Message 10 of 27
solovjev
Or sorry, I posted it to wrong window
Message 11 of 27
Civil3DReminders_com
Yes you can.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 12 of 27
i found it - thanks
why couldn't i use that as a structure table
(might work)
Message 13 of 27
While beating this dead horse "more deader". The LandXML out will only
include the pipes/structures that are to be changed to the other network.
Bill
wrote in message news:5995826@discussion.autodesk.com...
Two 2s by mistake.
Message 14 of 27
It would work, just lots of overhead managing the labels, especially when they move.
Christopher
http://blog.Civil3DReminders.com/
Civil Reminders
Message 15 of 27
okay - does anyone know why my label is doing this on some structures and not others
(see attached)
Message 16 of 27
csevers
So this was never solved? Nobody knows the command to swap networks, similar to swap parts?
Chris Severs, PE
Windows 7 Enterprise SP1 64 bit
64.0 GB RAM
Intel Xeon E5-2650 v3 @ 2.30GHz
NVIDA Quadro M4000
Civil 3D 2014
Message 17 of 27
troma
in reply to: csevers
I believe since 2010 you can split and merge networks.  So split the items from the network they're on, then merge that new network into the one you want them on.
Mark Green
Working on Civil 3D in Canada
Message 18 of 27
abraC3Dabra
Use smart draft tool ($2 aud)
https://apps.autodesk.com/CIV3D/en/Detail/Index?id=7296149598979862869&appLang=en&os=Win64
Use the tool to create a 3D polyline of the existing pipes you wish to shift over
Create pipe network from object under your desired network
Message 19 of 27
juliacarroll5102
i love this, been 11 years and i'm still not seeing a decent answer.......................
such a shame
Message 20 of 27
ralrefaei4HXVJ
Select all the pipes and structures that you want to move and choose the "split network option, and then it will give you the option to select the network that you want to move the parts into.
Rail Community
