Civil 3D Forum
Moving multiple lines to a spline
2 REPLIES 2
milandrimuller
759 Views, 2 Replies
Hi guys
I need help, i have a bunch of short lines i want to move to a line that is not vertical or horizontal, the line have a bit of a curve.
What command can i use to move these lines?
2 REPLIES 2
Welcome to the forums.
Other than the Move command I don't know because I don't know what you're trying to accomplish. There are different ways to Move lines using the Move command or using Grips. But I have a feeling that you're looking for something else.
Can you give a more detailed explanation of what you want? It also helps to tell us the version of Civil 3D you're using.
Allen
Allen Jessup
CAD Manager - Designer
tcorey
in reply to: milandrimuller
By "move" do you mean turn these straight lines into a curvy line? If so, use Pedit command and join the lines into a polyline, then use Pedit to Spline fit or Fit curve.
If by "move" you mean you want to move the lines along a curve, use the Rotate command.
Maybe you can post a sketch of what you're actually trying to do.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Rail Community
