When I try and move some of my cross sections in model space the vertical grid gets very large. Can not figure out why this is happening. Any suggestions very much appreciated. And using Civil 3D 2014
Are you using the move command and Windowing the CS View?
I've seen that happen as C3D thinks your are moving the actual Section elements (same with Profiles).
Do you get the same result if you just select the view and use the grip to move it?
HTH
AWood
