see the elevations on the grid. In my master drawing, they are all running along the bottom. After I cut the sheets, the offset no longer is where I want it. I was hoping I could just do a move command and drag them down, but they wont move. Any body know if there is a way I can move these easily without redfining the style? Thanks
If you band is just the elevations, you can adjust the location of the band on the profile view in the Profile View Properties on the Bands tab. You can offset bands from the bottom or top of your view.
If the band has the elevations AND the stations, you'll need to adjust the style.
