Jeff_M
Message 11 of 17 (322 Views)
Re: Move/Rotate entire drawing
02-15-2012 12:49 PM in reply to: glen.cameron
If you need to maintain the connection to the FBK's, someone else will have to jump in here. If not, you could just explode the figures to 3dpolys and move them.
Valued Contributor
glen.cameron
Message 12 of 17 (321 Views)
02-15-2012 12:54 PM in reply to: Jeff_M
Thank you for your time and words of wisdom.
I would prefer to maintain the figures, so I hope someone else may have another suggestion or two to try. :smileyhappy:
Glen W. Cameron, C.E.T.
Engineering Technician 1
City of North Bay
North Bay, Ontario, Canada
Valued Contributor
TCARCAMO78
Message 13 of 17 (311 Views)
02-15-2012 02:15 PM in reply to: Jeff_M
can you extract the figures thru the xref using the copy nested objects command onces you have the old drawing aligned with the new base drawing?
Tony
CAD Manager
www.tonyscivil3dworld.blogspot.com
Tony Carcamo
CAD Manager
Member
davehi
Message 14 of 17 (299 Views)
02-15-2012 06:16 PM in reply to: glen.cameron
Have you tried using the Translate Database command?
You can use it to move alll the data in the suvey database to a new location.
DaveH
Dave Hill
Neilw
Message 15 of 17 (296 Views)
02-15-2012 07:57 PM in reply to: davehi
I'm not an expert on the Survey Database but it is my understanding that one of the strengths of the survey database is the ability to reproject the survey to other coordinate systems. Thus you should be able specify the transformation parameters to project your local survey to a UTM.
Richard Sincovec (sinc) can probably help with the workflow. You might try giving him a ping.
Neil Wilson (a.k.a. neilw)
Infrastructure Suite/C3D 2013, LDT 2004, Power Civil v8i SS1
WIN 7 64 PRO
HP Pavillion h8xt, i7 2600, 12 GB
RADEON 6450, 1 GB
http://www.sec-landmgt.com
Active Member
fordtruckman
Message 16 of 17 (218 Views)
12-17-2012 08:07 AM in reply to: glen.cameron
This is the issue I cannot find a solution to.  How do you "unlock the survey database?"  I have read many people say that's what needs to be dont to rotate or edit survey points but then I haven't seen anyone actually explain how to do it.  The closest I got was "Prospector-Settings-Point-(right click)-Edit Feature Settings-Update Points-'Allow Checked In Points to be Modified'-True"  except then the points still won't rotate.
Any ideas?  I'm trying to rotate a preliminary survey about a point a certain number of degrees to match existing survey data.  Everything in the drawing rotated except the survey points....
Member
davehi
Message 17 of 17 (190 Views)
12-20-2012 04:09 AM in reply to: fordtruckman
Give this method a try if you wish to adjust the Survey Database.
From the Survey Toolspace open the Survey Database you want to edit.
From the Survey Ribbon choose the "Modify" band from the Modify panel.
Pick Translate database
(you could also enter "Translatesvdatabase" at the command line to run it)
The Translate Survey Database dialogue box will open and then you can set your basepoint, rotation angles, etc. which will move the entire database to the new location.
Import the points from the surveydatabse as usual.
Dave Hill
