Another approach is to use the AutoCAD .XY filter while selecting the new
location and then responding to the prompt for the Z value.
Laurie Comerford
www.cadapps.com.au
"wfb" wrote in message
news:5020033@discussion.autodesk.com...
Try this method:
Draw a line from your point to where you want it to go. Make sure the line
is at 0 Elev.
Move point by snapping from one end of line to other end.
(I believe a group of points could be relocated at the same time, if
needed.)
Bill
wrote in message news:5019811@discussion.autodesk.com...
Hello
If to move C3D point to specified distance -to some polyline, what is on the
0-level. then how to lock point so it would not change the level that it
has.
Thanks!
