All,
Awhile ago I read a post that gave instructions on how to move the window arround with the arrow keys and I just can't find it. A little box popped up in the upper left hand corner that allowed you to move the drawing window around to find a hidden dialog box.
Sorry I am not sure of the terminology.
In 2013 Civil 3d I am having the issue that when I select the Add/ Delete scales the cursor changes to an arrow and the program waits. If i hit the exscape key it goes back to normal. My best guess is the dialog box is popping up behind the drafting window.
Solved by troma. Go to Solution.
Mark Green
Working on Civil 3D in Canada
Mark Green
