Civil 3D Forum
Move All Lines to 0 Elevation
14 REPLIES 14
Message 1 of 15
22981 Views, 14 Replies
I am sending a drawing to an outside firm that wants all our lines to be sent to them at elevation 0. If I export my drawing to a ACAD file all the feature lines turn into polylines at elevation. Is there a lisp routine or someway faster than selecting lines, contours, ect. and manually putting them down to 0?
14 REPLIES 14
Message 2 of 15
Command: FLATTEN
Message 3 of 15
I am also trying to drop all our plan design lines to 0, unload all xrefs, type in "flatten", select all design lines
and they all go to an elevation of like 3244 something.
Why not 0?
Message 4 of 15
also noticed when you flatten leaders with text they explode or break apart, and you cant move the text anymore and have the leader stay with it!
Message 5 of 15
The only problems I've ever had with flatten is if you chose to remove hidden lines- things start to dissapear. So, I've always been able to use flatten and the items have always gone to zero elevation and not something else.
Have you tried selecting all your stuff, then using the properties window, change your selection set (where is tells you how many items selected) to each item, like lines, plines, txt, ect.... and set your z elevation to zero?
Hope this helps, and, I'm out of ideas on it. Maybe somebody has lisp routine they would be willing to share.
Message 6 of 15
Civil3DReminders_com
Are you in World UCS when you check?
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 7 of 15
Yep, I never leave world ucs.
Message 8 of 15
One other thing, when you flatten everthing, and it puts everything at some random elevation, is everything at that elevation? If so, them use the move command and move by the z elevation down.
Just throwing out all ideas to the table...
Message 9 of 15
MikeEvansUK
I have had this happen a few times myself, when you select a poyline the elevation displays as a strange nonsensical number.
Instead follow this workflow.
Explode from Featurelines to 3d polylines.
Convert from 3d Polylines to 2d poylines.
Now explode these polylines to lines.
use flatten or use the properties and change Start/End Z levels to zero.
Use Pedit Multiple to join all lines together again.
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Message 10 of 15
AllenJessup
If they're just lines or Plines you can change the elevation en masse in the properties window
Allen
Allen Jessup
CAD Manager - Designer
Message 11 of 15
MikeEvansUK
Normally that will work but there is some kind of a glitch which produces a polyline with a very strange elevation value. When you change the elevation rather than moving vertically it relocates in the horizontal planes.
That's why I sudgested the method as stated, it's the only sure work around that I have found works.
Mike Evans
Message 12 of 15
c.bergthold
I've noticed if you have a line with different start and end elevations, convert it to a polyline and they try to change the elevation the line will move into outer space.
Cory
Message 13 of 15
I imported a plan from AutoCAD to sketchup to form the model then I noticed that all the lines are not in a same line...I checked my cad file and noticed that it has become a 3D ....can I make my all lines to the same level?? I used flatten command it is not working...plz help
Message 14 of 15
buckP3YQT
FLATSHOT is better, but it does the entire drawing at once. It also can flatten to current isometric view. Make sure your view cube is on top if you want straight lines when you get done
Message 15 of 15
in reply to: buckP3YQT
Rail Community
