Are you moving the Admin image by hand to the new location? I believe this
doesn't work and was a problem discovered by QA, which I am not sure it was
documented in the readme. There is a previous thread in the newsgroup with
the title "Service Pack 1 Network Install problems" where Matt, one of our
QA engineers, describes step by step the process of applying SP1 to an Admin
image. You may want to take a look at that thread.
Also, you may want to try to create a new admin image from scratch and
applying the patch to it.
Thanks for reading.
Isaac Rodriguez
Software Engineer
"cwitzel" wrote in message
news:40200b7c$1_2@newsprd01...
> Everything was working fine not that long ago but now:
> I have created an admin image and applied the patch at this time.
> No no matter where I place the admin imkage I get a message saying I need
to
> shorten the path. this installs to H:\Misc I can't get much shorter than
> that.
> So instead of the shortcut I have just been double clicking the MSI file.
> Everyhting installs fine but I can't get it to authorize. I have LDD 2004
> and CD 2004 both authorized.
> Thanks for any help,
> Conan Witzel
