Civil 3D Forum
Modify the vertical scale factor on the surface.
4 REPLIES 4
rpichardo
2959 Views, 4 Replies
How can I to modify (exaggerate),  the vertical scale factor of the surface when I am seeing on the object viewer option.
4 REPLIES 4
troma
in reply to: rpichardo
Edit Surface Style > Analysis > Elevations > Elevations Display Mode
Mark Green
Working on Civil 3D in Canada
rpichardo
I did that, but I did not see any change, I attached something where I am explaining on detail my case.
neilyj666
Like this - may only work for triangles?
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
jeremy.2012
http://www.cadapult-software.com/article_info.php/articles_id/119
This worked for me.  I've been wanting to look at my surfaces with a vertical exaggeration in object view and finally found a way.  Enjoy!!
Rail Community
