I'm modeling a hydro scheme access track about 4m wide that meanders down a steep hillside at 1:8 with a couple of hairpin bends where the gradient is 1:20, what is the best way to model this?I have got polylines to define the hairpin and also offset alignments but I need to ensure that the outside edge of the hairpin at entry is used as a level target for the inside edge on exit for the length of the hairpin
I read a little differently. It sounds like he wants to ensure that the inside edge of the road stays at reasonably the same elevation around the curve, as the centerline profile drops at 5%.
BTW - is it 4m wide all the way, or are there widenings through the curves?
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
