This is primitive wording as I don't understand orientation very well.
Have model with North orientation vertical on screen. Would like to rotate model so north on screen is to right. to make it easier to work on, but don't want to change coordinate system. Sort of analogous to MVIEW. HOW?
Solved by Sinc. Go to Solution.
Worked fine! Along same line--when I edit label style and change rotation angle from 0 to 270, the leader disappears.
