Hello
I have a qusetion about surface for so long .I show you my problem in two examples:(plz download Attachment)
1-In Surface file1 i made surface and i set contour smooth in last step but after that i see contours interfer each other!! in concept it is completely wrong but civil 3d dose it without any warning!!!!(because in this status triangles should interfer each other)(pic 1)(File 1)
2-In another file i made surface from contour and i minimized flat area(without any smoothing) but again i see contours interfer each other(pic 2)
I'm working with civil 3d 2010
You have the smoothing value set too high. Try reducing it. Made a big difference to me. See attachment.
Thankyou for your reply
Yes it is right but i don't know why civil 3d creates these surfaces without any logical reason and concept .for second file it is not acceptable surface at all.
plz download file2 from :
http://www.4shared.com/file/q13E3mNb/File2.html?
The quality of the original information will also affect the surface i.e. if the points are widely spaced then there is more scope for inaccuracies when contoured.
Additionally, the use of breaklines to define tops and bottoms of slopes (rather than only using points) can also help in some instances
Matt,
To borrow from another frequent poster, Joseph D. Bouza, P.E., "All Contours Are Lies!" Smoothing doesn't make the surface any more 'inaccurate', since TINN surfaces are still an approximation. There is no telling what happens between shots in a TINN, and real world surfaces are not made of flat 3d faces pasted together with sharp edges between points. Smoothing contours is a legitimate way to make the drawings appear more real, but can easily be over-done.
I prefer to use the 'smoothing' routine in the surface edits, where I can select regions to smooth the contours instead of the entire surface. This allows me to get rid of angular contours in flat areas, but leave sharp breaks at my slope breaks. Bonus, it adds points to the surface to smooth out the contours, so the contours stay accurate to the TINN!!
Here's a visual example of what I was talking about.
This first example is an open region between my edge of pavement and a slope about 200 feet away.
I added a 'smooth surface' for a small portion of the surface using the 'Natural Neighbor' method.
And it added points to smooth out the area for me, leaving sharp edges at my slope.
I hope this is helpful!!
