@za_julie wrote:
The missing start/end chainage issue is a bug in the program. The solution, given to me by my local Autodesk retailer, is to turn OFF the last four label bulbs in the display tab. See attached screen shot.
It's counter-intuitive to turn them off, but doing so makes the start/end chainages show up.
Julie
I've been trying to fix this forever, and this worked for me, still an issue in 2012 version of Civil3D. Thanks!
Have you checked the label components of the Horizontal Geometry Point and Vertical Geometry Point labels in the profile band style? (Profile Data Band Style -> Band Display tab -> Label and ticks list box -> Horizontal Geometry Point then click Compose label.. button)
I've been caught out on some drawings where the band styles were not fully configured.
Have you verified the correct profiles are mapped to the band?
I also have this problem. One way to fix it I found is to start the profile at 10+00.01 instead of 10+00.00 (as an example). For some reason, the 0.01 at the end of the station to start the profile makes the beginning station appear on the Profile View.
Your reply reminded me of a message I posted previously here -
Adding a minus figure to the station range also works in the user specified range start field.
There is also on Profile View Properties >> Bands >> set the weeding factor to zero.
This one catches me out from time to time.
Dear All,
Have you checked the "Data Source" in the band?
You have to choose and set the right Network source. If empty or wrong pipe network is chosen you won't see any label in the Profile View. This "Data Source" is on the main Profile View Properties window. ( I lost half day to find it :(.)
Had same issue and got it fixed by untick "Profile Start" and "Profile End" at Geometry Points to Label in Bands->Profile Points while tick "Alignment Beginning" and "Alignment End"
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
This is the correct answer.
the label info was empty.
Had this problem for a while
thanks
