Civil 3D Forum
Missing Profile Labels
2 REPLIES 2
jpapez
329 Views, 2 Replies
When trying to create roadway profiles in Civil 3D I ran into a labeling problem. I cannot get my vertical curves to label their starting and ending stations or elevations. In toolspace under
Profile
-Label Styles
-Curve
-Standard
I right clicked and selected "Edit" and picked the "Layout" tab. I understand under the heading "Component Name" pulldown I Should have the option of selecting BVCS and BVCE ect. but the only labels showing up are "Dimension Line, Start Line, End Line and Length".
Is there a setting I have not selected or some option I am missing. Please help
2 REPLIES 2
in reply to: jpapez
If you attached Drawing I can see exactly.
but I think You are off label in display tab. or somtimes drawing error.
last week my drawing can not draw vertical profile, all setting correct but did it. so I recover drawing but cannot.
I make all drawing again. well done.
I don't know what's wrong
If your problem is going on, attache your drawing
stevef
in reply to: jpapez
Try using the profile band styles. I use 'band styles-vertical geometry' and create a TP (tangent point) style which has the station and elevation information for the start and end of vertical curves. (see attached dwg file)
Rail Community
