I hate this program!
I have a scenerio where grade labels are missing for any lines that extend beyond the edge of the profile view. (Please see the attached jpg.) The scenerio is similiar to the problem described in the following discussion group: http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Profile-labels/m-p/3624892#M185643. I tried implementing the recommended solution by adding a line component and setting the anchor to "Tangent Start In View" and "Tangent End In View" without any luck. Does anyone have any more ideas to make this thing work?
I love this Program!
Sorry for your frustration
are you refering the the tangent grade to teh left? Copy the label from the adjacent view with a drag state without a leader? Add a PVI and don't show its label? Cange the weeding value of the line label? Add another Line label in the composer that anhors to the right end?
Your Name
Your Name
Joe,
Jeff,
Jeff,
Here are the settings for the line component.
Jeff,
I'm not sure I'd consider that a defect. The line is using Start in View and End in View, in that order. I read it as the start & end are station value, so it starts on the right and ends on the left (opposite of what the profile view that reads left to right does). If I flip the values of the line it works as expected.
IMHO
Thanks, Lisa. I should've posted that I tested the flipping of the anchors as well, however it did not work in my case (also in 2012 SP4). Here's an image showing the settings for the labels in the reverse direction, yet the same labels do not show in both profile views (the one on the right uses the original label style).
Lisa,
I just tested your solution on my computer, and it's still not working for me. Right now, just to move the project along, I placed static, dumb mtext objects with the correct grade. Then, I added a cloud and note on the Defpoints layer letting me know "Hey. Stupid. This is a dumb mtext and will not automatically update."
