Civil 3D Forum
Missing Language Pack
17 REPLIES 17
Message 1 of 18
2909 Views, 17 Replies
{color:#333399}All of a sudden out of the blue when I open certain dwgs in civil 3d 2008, I am getting a dialogue box to use windows to install a missing language pack for chinese, thai, arabic to name a few. I have option to open or close the box...or never show dialogue again...but its still around...The stuff that twilight zone is made of. Anyone have this abnormal thing happen to them as well?{color}
17 REPLIES 17
Message 2 of 18
mbissell@msaonline.com wrote:
> {color:#333399}/*All of a sudden out of the blue when I open certain
Who worked on the drawing last? You should only get this when a
non-native language version of AutoCAD was used to edit the drawing.
See also:
http://usa.autodesk.com/getdoc/id=TS1061030
R.K. McSwain
http://cadpanacea.com
Message 3 of 18
tmullins
The exact same thing happened here to us over the last few weeks...must be something in the air.....
What is weird we'll get it in a drawing one day, then the same drawing next day (or an hour later) and no message. I'm wondering if some sort of Windows patch/update goofed something up.
Message 4 of 18
Came from survey dept. in our office here in Hampton Roads, Va. and we only speak english.
Message 5 of 18
I'm with ya on the one day it's here one day it isn't. That's what I meant by twilight zone stuff.
Message 6 of 18
tmullins
Glad to hear we're not alone. I thought for a while we opened an office in Beijing and no one told me.
Message 7 of 18
suet1
I have been seeing the same thing for over a year. I always figured it was because I'm opening a map used by a co-worker that works from home and uses her version of Map3D. When she's finished, she logs in remotely and transfers the drawing back in. Then someone in-house opens it and we get that message. It only seems to happen on the maps that are shared like that - but like you, it's not everytime.
Message 8 of 18
Happens all the time..two to three times a week. That check box that you tick not to show that message again does nothing.
Message 9 of 18
A missing language pack may also indicate that you have a virus (Acad.vlx virus).
Message 10 of 18
See KnowledgeBase Doc: http://usa.autodesk.com/getdoc/id=TS13717811
Himanshu Gohel. Civil 3D Team, Autodesk, Inc.
Autodesk Civil 3D Product Information: http://www.autodesk.com/civil3d
Civil Engineering Community Portal: http://civilcommunity.autodesk.com
Message 11 of 18
We've followed the cleanup process indicated in the Autodesk Knowledge Base......didn't do a thing. Still get the Missing Language Pack message almost all of the time.
Message 12 of 18
Matt.Anderson
What version are you using?  2009?
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 13 of 18
mathewkol
This removes the virus from the computer, correct?  The dwg file is still "contaminated"?  Is there a way to decontaminate the file?
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 14 of 18
Running Civil 3D 2011
Message 15 of 18
Matt.Anderson
Have you customized you parts with Part Builder?
Product Manager
Autodesk (Innovyze)
Message 16 of 18
in reply to: Matt.Anderson
No, haven't ever used Part Builder.
Message 17 of 18
We started getting this come up at our office last year and so I had everyone go through the instructions for the acad.vlx virus and it went away (or we stopped getting the messages anyway).  But as soon as I installed C3D 2011, I am getting it again on every drawing I have opened so far (which is only a few - I am not sure if I should open too many).  I went through the instructions from here http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13717811&linkID=9240617 again for my 2011 installation and I still get the messages.  These are drawings that were created by me and used only by me from an English based install.
One other thing.  No one in the office ever found the logo.gif file, acad.vlx file, or the string of text mentioned in the virus fix.
Message 18 of 18
I came across this forum when I was searching for an answer to why I was getting the missing language pack pop-up suddenly in Civil 3D 2013.  It first started when I received a drawing from outside of our company.  It has now since spread to new drawings we created inhouse from our templates.  I reviewed the instructions from here http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13717811&linkID=9240617 and never found the the logo.gif file, acad.vlx file, the string of text mentioned in the virus fix, or the ACADLSPASDOC system variable changed to 1.  I've wblocked items out and even backsaved files.  This is only a temporary fix, since later on when the file is opened it eventually displays the missing language pack dialog box.  It's quite annoying especialy since it seems to be affecting another computer in my office.  Is there a solution to fix this?
We are using Civil 3D 2013 Service Pack 2.
Rail Community
