Good Morning!
I don't use stationing or alignment tools in Civil 3D very often. I have a project where I need to do a plan and profile. The plan view I have had to use the Dview>Twist at a 45 degree angle in the viewport. My minor stationing labels are showing up in the viewport upside down. I have gone in and changed the bias in the label style, some labels changed, but others did not. Any suggestions?
Thanks in advance!
Solved by Pointdump. Go to Solution.
Try selecting an Alignment label > Right click > Edit Alignment Labels > Edit the Minor Station Style being used here > General Tab of Label Style Composer > Plan Readability > Plan Readable "True" > Readability Bias 110 deg.
Kim,
I've seen that behavior with a UCS. I've had to "flip it over" to get the labels "un-backward". Is your ViewCube upside-down?
Try Dview >> Twist >> (Minus)45, or (Minus)225. See what that does.
Dave
Dave Stoll
Las Vegas, Nevada
