Civil 3D Forum
Minimum Pipe Cover Question
6 REPLIES 6
jbalaneski
529 Views, 6 Replies
I am using a Pipe Network for all my drainage culverts on a large industrial site.  I have created all my pipes from "Create Pipes from Object", which were all feature lines.  While generating the pipes, I told it to use the object as my pipe invert.
I have set up my pipe rules (i.e. minimum/maximum slope and cover) to what I want.  Also when creating my pipes I assigned my design (top of subgrade) surface to them.  But I noticed that it's calculating my pipe cover from the middle of my pipes.
My pipes all have the right wall thickness, etc...set in the style.  Is there a setting I'm missing telling the pipe to calculate it from the top of hte pipe...instead of the middle of the pipe?
6 REPLIES 6
ToddRogers-WPM
in reply to: jbalaneski
In the create dialog, by default it is set to Center...
Todd Rogers
jbalaneski
in reply to: ToddRogers-WPM
Yes I set that to use the object/feature line as the invert of the pipe...but it's still reading the cover from the center of the pipe...
wfberry
I would not think that PIPE COVER would be anything but based on the top of the pipe.  Perhaps I am wrong but what if you did a quick "repair of your installation" and see if that fixes your problem.
Bill
jbalaneski
in reply to: wfberry
Ironically I already did a repair last week on my install to fix another issue.  I even had our IT department completely reinstall my C3D when that issue wasn't resolved.
ToddRogers-WPM
Have you tried deleting the rule and adding it again?  Or possibly clicking on the pipe, right-click, and Apply Rules?
Todd Rogers
jbalaneski
I will try that and let you know what I find out....Thanks for the suggestion 🙂
Rail Community
