Civil 3D Forum
Mill-Resurface Cross Section Issue
2 REPLIES 2
rcallison
399 Views, 2 Replies
Proposed Assemblies are not correctly reflecting the corridor assembly parameters the changes do not show up in corridor after the corridor has been rebuilt. The section shows that the left side of the proposed corridor and the right side of the proposed corridor are not the same when parameters for both sides are the same.  We are looking for help in manipulate the parameters and settings to correctly display in the sections.
2 REPLIES 2
That looks like an FDOT subassembly, you might want to contact them to see if they can provide more information. I know some FDOT hang out in the forum, so they may see it. Did you check the error message in the file or the geometry log?
In using this type of subassembly before there is usually a tolerance value because the mill is being taken from the surface and the solution may be within that tolerance making the slopes on either side be different.
Jason.Ferrelli
in reply to: rcallison
I have seen cases where a drawing will become corrupt and will then not update correctly. If you start a new drawing and use those same subassemblies, do they work in that new drawing?
Jason Ferrelli
Rail Community
