I am trying to overlay a large area,I have a design profile grade that I must use. I need the new edge of the overlay pavement to be 2" above the existing as long as the pavement cross slope is between 1% to 1.5% . If the slope goes above or below the min or max I need it to take the min or max. If I use the overlaymillandlevel2 I am unable to get it to use the overlay thickness since i am using a profile. Does anyone know how I can do this?
thanks
civil 3d 2011 with all service packs, Window 7
Intel E5630 @ 2.53GHz 2.53GHz
8 Gig Ram
Solved by fcernst. Go to Solution.
I needed the slope from the PG at centerline to 2" above existing pavement edge. I have abandoned the rehab assemblies and am using generic links and it appears to be working.
Thanks and have a great day
Right. That should work now with the constant offset assumption.
