Member
dunganeng
Message 1 of 3 (82 Views)
Migrating Points from LDD toCivil 3D
82 Views, 2 Replies
01-13-2004 06:23 AM
I am trying to migrate a LDD project to a Civil 3D project. I can't get the existing points that are in my LDD project to the Civil 3D project. Should these existing points show up in my new Civil 3D project?
*Henry Sanders
Message 2 of 3 (82 Views)
Re: Migrating Points from LDD toCivil 3D
01-15-2004 07:44 AM in reply to: dunganeng
For the present time, points have to be in a drawing that is attached to a project. To get LDT points into a project, do the following: Points menu > Create Points > [Category:] Import Points > [Command:] External Project Point Database -- Henry Sanders Autodesk ISD Civil Test Development "dunganeng" wrote in message news:19379251.1074003820317.JavaMail.jive@jiveforum1.autodesk.com... > I am trying to migrate a LDD project to a Civil 3D project. I can't get the existing points that are in my LDD project to the Civil 3D project. Should these existing points show up in my new Civil 3D project?
*Henry Sanders
Message 3 of 3 (82 Views)
01-15-2004 08:07 AM in reply to: dunganeng
I forgot to mention, that once the Points are in the Project Drawing, they then need to be added to the Project using the following steps: Select the Drawing Point node Select the Points in the item list and right click Select Add to Project and chose the desired option from the Check in options. -- Henry Sanders Autodesk ISD Civil Test Development "dunganeng" wrote in message news:19379251.1074003820317.JavaMail.jive@jiveforum1.autodesk.com... > I am trying to migrate a LDD project to a Civil 3D project. I can't get the existing points that are in my LDD project to the Civil 3D project. Should these existing points show up in my new Civil 3D project?
