Civil 3D Forum
Microstation to Civil 3D adding surface request for information
8 REPLIES 8
Message 1 of 9
transmartinc
1069 Views, 8 Replies
Hello all,
Quick background here: I'm mainly work in 3D software (C4D, 3Ds Max). I have a client that wants to do high end traffic renderings. They have supplied me with the Infastructure Design Suite 2014.
I received an old Microstation file from them, which I have then brought in to Civil 3D. I would like to add surfaces to this file so then I can export to 3Ds Max, and use Civil View to incorporate the design, and then traffic simulation data from VISSIM.
I have researched the entire work flow, the only thing holding me up is adding the surfaces to this Microstation file. It seems this is maybe not very common as I am having a hard time finding any tutorials or documentation on the internet.
Can anyone point me in the right direction to where I might be able to find resources on accomplishing this?
Thank you taking the time to read this 🙂
8 REPLIES 8
Message 2 of 9
_Hathaway
in reply to: transmartinc
Getting an exact copy of a Civil3d surface to Microstation via any type of export functionality has proved impossible for us. We stopped trying and simply do the work in Microstation now.
Message 3 of 9
transmartinc
in reply to: _Hathaway
Thank you for the response.
However, I am not trying to do any work in Microstation. I have a design for a round about that the client did some years ago (which was done in microstation) I want to take the DGN and place it in Civil 3D(which I have done) I now want to add a surface to that, so I can export everything to 3Ds max.
My problem is figuring out how I can add surfaces to this file.
Message 4 of 9
It depends on what is in the DGN file. Is the geometry at elevation or at 0. Making a surface from the graphics is a pretty straight forward process provided the information has elevation.
Peter Funk
Autodesk, Inc.
Peter Funk
Autodesk, Inc.
Message 5 of 9
Peter,
Thank you.
That is where I'm hitting a wall. I believe all of my information is at 0. Resulting, I need to give it elevation to add a surface. Which, I'm not certian how I should do that. (I'm a 3D render guy just now jumping in to Civil 3D/Civil View).
I was thinking I could create an Alignment from Object (by selecting my center lines from the DGN) Once I get there, I try creating a profile cross section so I can give the alignment a road defention but I have all sorts of issues.
The road I'm trying to make for this purpose can be perfectly flat, I am not worried about grade, or exsisting ground. I am purley trying to make a surface in order to get something in to 3Ds Max at the moemnt.
If you have a moment, I've attached the file for you to take a peek at.
Thank you
Message 6 of 9
Neilw_05
It appears the DGN you received contained only the 2D planimetrics. I don't see anything in the file you can use to build a surface. You will need to obtain the surface data either as 3D triangles or in a LandXML file.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 7 of 9
g_k50
Quick and Dirty, this is what I would do.
Revise the existing autocad drawing so that all entities are on the zero elevation.
create a surface in autocad at the zero elevation using the entities in the drawing.
Export as needed.
Message 8 of 9
doni49
in reply to: g_k50
Export as needed.
That would create a totally useless surface EVERYTHING in it would be at zero elevation.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 9 of 9
transmartinc
in reply to: doni49
Thank you all, I'm getting GIS data from the area, and I'm going to attempt to use that data to obtain some elevation data to make my surface.
I was hoping there would be some sort of "default" land/plane I could use in all this, but owell.
Thank you for the replies!
Rail Community
