We've received a DXF of contour data that is metric and in a metric grid. I import the DXF, create a surface and check the surface style and the file defaults to imperial settings even though my Qnew settings are all metric. The edit drawing settings end up being in feet.
Options-> template settings, are metric.
Is there a spot where you have to specify the template for DXFs, or is there a setting I'm missing somewhere? Could it be that the DXF really is not metric?
Thanks in advance
Canon
