Is there a known cause for CAD crashing if you open the MetaData Viewer?
Have tried to open it with "MAPMETADATAVIEWER" as well as through the map workspace. Have tried it in drawings with and without map data attached to them as well. Is there a temp file location I may have in a bad place or some other possible cause?
Enter this in the Run Windows Box
%temp%
Delete all the files that you can in this temp folder. If a file is necessary it will not delete.
Bill
Thank you for your response.
I followed your instructions and also made sure I had C3D closed before doing so. Deleted a ton of files, but the problem persists.
