Civil 3D Forum
Metadata Viewer crashing
2 REPLIES 2
asloat
155 Views, 2 Replies
Is there a known cause for CAD crashing if you open the MetaData Viewer?
Have tried to open it with "MAPMETADATAVIEWER" as well as through the map workspace. Have tried it in drawings with and without map data attached to them as well. Is there a temp file location I may have in a bad place or some other possible cause?
2 REPLIES 2
wfberry
in reply to: asloat
Enter this in the Run Windows Box
%temp%
Delete all the files that you can in this temp folder.  If a file is necessary it will not delete.
Bill
asloat
in reply to: wfberry
Thank you for your response.
I followed your instructions and also made sure I had C3D closed before doing so. Deleted a ton of files, but the problem persists.
Rail Community
