Civil 3D Forum
Message when opening certain drawings
11 REPLIES 11
Message 1 of 12
neilyj666
372 Views, 11 Replies
I get the attached when opening certain drawings which fails to load my acaddoc.lsp and so several useful lisps don't get loaded.
Any ides what's causing it - a successful drawing opening shows the following
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
11 REPLIES 11
Message 2 of 12
troma
in reply to: neilyj666
Is it related to being unable to locate the project?  I don't know why that would kick out your lisp, but that's what it looks like.
It seems to me that we get that "unable to locate project" message when opening a drawing on a machine that doesn't know where to look for the data shortcuts "Working Folder".  It looks in the previous working folder and can't find the "Project Folder".  That's why we've started putting all our "Project Folder"s into one "Working Folder".
Mark Green
Working on Civil 3D in Canada
Message 3 of 12
ToddRogers-WPM
Do you happen to have that Label Assemblies add-on from Autodesk Exchange installed?
Todd Rogers
Message 4 of 12
neilyj666
in reply to: ToddRogers-WPM
Yes I do - is this the culprit?
Message 5 of 12
ToddRogers-WPM
Yes sir.  I also have it installed, that's why I asked.  I have seen this before Smiley Wink
Todd Rogers
Message 6 of 12
neilyj666
Do you know for sure?? I have many other add ins as well but only have seen this recently
Message 7 of 12
ToddRogers-WPM
I uninstalled it and the message doesn't appear anymore.  Let me rephrase that, I formatted my machine and didn't reinstall it, and the message doesn't show up anymore.  So to be sure, I can reinstall it right now and let you know if it appears again.
Todd Rogers
Message 8 of 12
ToddRogers-WPM
That's a negative neilyj.  I'm still not gettting that message after reinstalling the CGS Label Subassembly.
Todd Rogers
Message 9 of 12
neilyj666
Thanks for trying - I can live with the hassle as it seems to just be one drawing that is affected and I can load the lisps if needed manually.
If it persists in other drawings i may need a rethink.....but as I'm on new msachine and a fresh install hopefully its an isolated occurrence
Message 10 of 12
neilyj666
Seems to occur only when I open a template drawing (for my sheet set) that has been saved whilst in paperspace. My usual template is saved in modelspace and doesn't show this behaviourSmiley Frustrated
Message 11 of 12
AllenJessup
Maybe Recover the template and save it from ModelSpace?
Allen Jessup
Allen Jessup
CAD Manager - Designer
Message 12 of 12
neilyj666
in reply to: AllenJessup
I'll try it
Rail Community
