Civil 3D Forum
MES Top Elevation in Structure Table
4 REPLIES 4
535 Views, 4 Replies
Is there a way to show the MES Top Elevation as blank or a dash? It would be great if I could make an expression but without the use of text strings in the expression editor, I don't know how to accomplish this without using wipeout boxes over the elevations. Any suggestions?
4 REPLIES 4
I am looking for this same answer, I have a structure table with both roadway and drainage inlets and mes, I want rim elevations to show for road inlets, grate el to show for drainage inlets and no line at all for mes'. I can not find where it put this in the styles. Any help would be great!
jggerth
guess no answer yet?  I'm running into this as well.
in reply to: jggerth
Same here. I also want to be able to call out an EOP elevations on my curb inlets and a rim on manholes within in the same pipe networks. Seem impossibile. Flexability with limitations.
Good Morning Alex, since posting this two years ago i have had a work around\solution of just making seprate styles for my structure tables. It is easy enough to make several different ones, and then you can just pick and choose what goes in what table.
Rail Community
