When pushing F1 for help in 2012 Civil 3D regarding this feature, it takes me to a page about migrating custom files over.
It says to copy the pipe/structure files over, then to open up Civil 3D and type in PIPECATALOGREGEN. Well, it doesn't work and says that it is an unknown command.
What's going on?
Mark
Solved by m177. Go to Solution.
See attached image.... The instructions from 2012 Civil 3D say to type in PIPECATALOGREGEN.
But it is wrong.
After spending more than an hour trying to figure it out, I mistakingly typed in PARTCATALOGREGEN instead, which worked.
Autodesk, if you haven't already fixed it in 2013, please put it on the list of things to do. It can save people tons of time like it could have for me.
