Active Member
paorconsult
Message 1 of 7 (14,365 Views)
merge surfaces
14365 Views, 6 Replies
04-16-2007 11:28 PM
i have create a corridor surface for my alignment and now i want to merge my corridor surface with my platform surface... what are the steps
sboon
Message 2 of 7 (14,366 Views)
Re: merge surfaces
04-16-2007 11:33 PM in reply to: paorconsult
- Create a new empty TIN surface
- Expand the surface definition area in toolspace until you can see the surface edits.
- Right click and select Paste Surface.
- Select the EG surface
- Repeat for the corridor surface. Your new surface will be a merge of the two.
Active Member
paorconsult
Message 3 of 7 (14,363 Views)
Re: merge surfaces
04-17-2007 12:00 AM in reply to: paorconsult
I noticed that the corridor surface that i create is not the surface by it own. it still in the corridor pack... is that mean i need to create another surfaces just for the alignment n coridor???
BrianHailey
Message 4 of 7 (14,364 Views)
Re: merge surfaces
04-17-2007 03:58 AM in reply to: paorconsult
What is up with the duplicate posts lately and why do I seem to always reply to the one that has no discussion on it?
Brian
p.s. This is not directed to you, paorconsult. It just seems to have happened to me a lot lately
Brian Hailey
CAD-1.com
My Blog
sboon
Message 5 of 7 (14,364 Views)
Re: merge surfaces
04-17-2007 12:16 PM in reply to: paorconsult
The surface created by the corridor exists as a separate object, but all of the definition data is part of the corridor properties. When you rebuild the corridor, the surface automatically updates.
You can use the surface just like you would any other, including a paste operation into a larger surface - or you can detatch it from the corridor and it will become a static object.
New Member
Forum_new
Message 6 of 7 (13,392 Views)
Re: merge surfaces
02-09-2011 01:19 AM in reply to: sboon
I think I have similar kind of issue in my mechanical 3d model. Please find attached immage for explaination of problem faced.
I would be thankful if someone can help me out.
New Member
felang
Message 7 of 7 (12,065 Views)
Re: merge surfaces
08-25-2011 07:18 AM in reply to: sboon
Once the merge has been made I notice any changes you have made to the “Point Label Styles” are reset; is there any way to keep the changes made to the label styles after the merging of the two surfaces?
