Civil 3D Forum
measuring from an alignment tickmark
2 REPLIES 2
wbrustle
385 Views, 2 Replies
How come when you try and check a distance on an alignment, and say I try and click on one of the tick marks it will not snap to the intersection of the tick mark....it like jumps off like half a foot and will not give you an accurate measurement? Has anyone else come across this?
2 REPLIES 2
Joe-Bouza
in reply to: wbrustle
Many Osnaps do not work with c3d objects. You can use the inquery tool or sta offst lable to determine the distance
Your Name
wbrustle
in reply to: Joe-Bouza
did not know that the regular distance command would not work on a Civil 3D object.....I used the dist. found under Inquiry and it snaps right to the intersection....thank you so much.....I always struggled with this:(
Rail Community
