How come when you try and check a distance on an alignment, and say I try and click on one of the tick marks it will not snap to the intersection of the tick mark....it like jumps off like half a foot and will not give you an accurate measurement? Has anyone else come across this?
Solved by Joe-Bouza. Go to Solution.
Your Name
did not know that the regular distance command would not work on a Civil 3D object.....I used the dist. found under Inquiry and it snaps right to the intersection....thank you so much.....I always struggled with this:(
