When I use MEASUREGEOM and then select the Angle option, it returns the angle rounded off to the nearest degree. Is there a way to make it more precise?
My dim settings are ok: when I dim label an angle it is precise.
Also, when I open Toolspace/Settings Tab and rt-click on the dwg name/Edit Drawing Settings/Angle the precision is set at 4, so those settings are ok.
Steve
C3D 2010
Solved by Jeff_M. Go to Solution.
Huh - I didn't know about measuregeom. It's been re-mapped to MG. You learn something new everyday.
That fixed it, Jeff. I appreciate it.
Steve
