Is it possible to create a table containing all volumes för my corridor? It would save some time instead of creating one table for each cut, fill, pave...
Solved by BrianHailey. Go to Solution.
Not that I'm aware of. You can create a report for all of the materials and then import that into your drawing. Wouldn't be dynamic to the corridor though.
On the Ribbon go to the Analyze tab->Volumes and Materials panel->Volume Report. Choose an appropriate style sheet from the next dialog (out of the box has one called Select Material.xls) and away you go!
