Does anyone have any experience using matchline labels in multiple viewports using the previous and next sheet formulas? Is there a way to use logic to tell it to use previous sheet if at the beginning of sheet and next sheet if at the end of sheet. Otherwise this previous/next sheet concept does not work.
That is exactly how I generated them. The issue is that there is one matchline that seperates two sheets. There is no way to tell it to say "next sheet #" for the right side of the viewport or "previous sheet #" for the preceeding sheet on the left side of the viewport.
If you look at the image, you have to create a label style for the left and right of the matchline. The left would display the next sheet info and the right display previous sheet info. You specify next and previous sheet is the label composer.
I have been there and done that. I think I am supposed to use the background mask function of the matchline style which will hide everything outside of the current sheet. However this function only works when in the sheet set drawing the viewport window is set to plan. This is fine, but not all of the labels on the matchline appear when the view port is set this way. Switching the viewport to undefined fixes the label issue but removes the mask. I assume that the program is trying to turn off the proper portions of labeling and not the ones that are being turned off. This way you dont need background mask.
Could you post a screen shot?
I actually figured it out. The left matchline label refers to the actual left matchline not the left side of the matchline and same goes for the right side. My fault...is it Friday?
