Hi All,
I created view frames and sheets for a number of alignments.
Is there a way to turn off a match line not associated with the main alignment for a particular viewport.
Please see attached to explain clearer.
Or did I missed a setting somewhere that should turn this off automatically?
Harold
Solved by Joe-Bouza. Go to Solution.
Your Name
There is a srtting for that. on the settings tab>> Match lines you can add a suffix or prefix to the layer name with -* , or *- and the alignment name can be appended to the match line layer
Your Name
HTH
Your Name
