hello,
I have a corridor which was created using intersection wizard. Is it possible to match frequence of corridor links which are going along two different curb returns?
Joe Bouza
and nothing happens. Probably I have beem misunderstood, thus I will try to repeat my question. I need that the links of corridors along both curb returns would meet at the same point on secondary road alignment. this would give me a much better surface.
In the Corridor Properties / Frequency you can click on the plus sign at the bottom to add additional stations, and the click on the end of your main road assembly.
Joe Bouza
yes, but is there a smarter way to do it, because now I can only add sections manually. It might be a solution, but unfortunately I cannot delele sections which I do not need, I can only delete sections which I added before.
