We recently changed to Autocad 2015 Suite where as until then i was working with a personalized 2010 version of the software for standard drafting and some mechanical modeling. The ultimate goal is to be able to do grading projects and calculations more expeditiously. I am very pleased to have the opportunity to do it. The problem is this new software is very quote"Robust" to the point where it is totally intimidating as to the basic project development and flow. I see there are two possible books that may help to redefine my way of doing business. Is there a recommendation as to which would be better or should i assume the last is the best match to my installation?
Mastering AutoCAD Civil 3D 2015: Autodesk Official Press
Cyndy Davenport, Ishka Voiculescu
ISBN: 978-1-118-86209-4
Mastering AutoCAD Civil 3D 2014: Autodesk Official Press
Louisa Holland, Cyndy Davenport, Eric Chappell
ISBN: 978-1-118-60381-9
jm
Solved by Joe-Bouza. Go to Solution.
Quite frankly, either book should work for you, not much has changed as far as techniques. Just to confuse you, Rick Ellis writes a real good book and is located:
http://cadapult-software.com/shop-cadapult-books/
Bill
JM,
I concur with Bill. Rick Ellis's books are very good, and his website has lots of tutorials and AutoCAD tips.
If you'd like a Grading-specific book, Ascent has a really good one:
http://www.ascented.com/courseware-solutions/autodesk/courseware/autocad-civil-3d/2015/civil-3d-2015...
Ascent also has one for 2015 Fundamentals:
http://www.ascented.com/courseware-solutions/autodesk/courseware/autocad-civil-3d/2015/autocad-civil...
And one specifically for Surveyors:
I bought the 2014 versions of all three, along with the 2014 version of Rick Ellis's book. I read all of them, cover to cover, and I rate them highly.
For some things, though, only this Forum will supply you with answers.
Dave
Dave Stoll
Las Vegas, Nevada
I haven't seen the 2015 Mastering book, but have used Ms. Holland's 2014 version in training classes. It was well received. The exercises are easy to follow and the explanations are in-depth.
Tim
To follow up on this thread, we have found a class in our local area which should help to jump start my mission. After that i will make a determination
as to which book or books will best serve my need. Thanks to Everyone for your consideration.
jm
I'm sure all the books out there have great content, but sometimes you have to get under the hood and scrape your knuckles.
Empirical data is your best teacher.
Joe Bouza
Joe,
"...sometimes you have to get under the hood and scrape your knuckles."
Now every time I open up C3D, I'm going to look at my hands.
Dave
Dave Stoll
Las Vegas, Nevada
I know I do Dave 🙂
Joe Bouza
To follow up on my progress so far. The books that i have now are the Autocad Civil 3D Essentials 2015 and Acent Autocadd Civil 3D 2015 fundamentals. The later was accompanyed by a 3 day introductory course and the book works fairly good for that purpose. I have been able to produce several smaller site grading projects and now beginning to struggle with the Styles and Annotation labyrinth. The question here, Is there printed documentation dealing with the organizational structure and definition terms of this maze of tangents?
jm
For a new and with little time for learning user, you can start AutoCAD Civil 3D 2015 Essential Eric Chappell
for a user with enough time to practice, Mastering AutoCAD Civil 3D 2015 Cyndy DavenportyIshca
All kindle format
greetings
Is there any information on Storm and Sanitary Analysis in the Mastering AutoCAD Civil 3D 2014 book? I know there are bonus chapters for download on the Wiley website, but I was hoping there were more examples in the published book. Thanks!
Mastering Civil 3D 2013 has a chapter on the Storm and Sanitary Analysis. Not sure if that version is still available or not though.
Thanks guys for all useful information, am new with CIVIL 3D have been playing with the software but am looking for a good practical book that give step by step approach to ROAD DESIGN USING CIVIL 3D. can you recommend any please. Thanks in advance.
Wisconsin has been nice enough to share their manuals with the public: http://wisconsindot.gov/Pages/doing-bus/eng-consultants/cnslt-rsrces/tools/civil3d/civil-train.aspx
