I'm using Civil 3D 2012 and I'm having a hard time to turn off a maker that I didn't recognize in 2011. While having all my Osnap tools turned off, I will make a Fillet between 2 polylines, but an automatic yellow marker keeps poping up on the screen (See PDF attachement).
Is there anyway to turn the yellow marker off?
Thank you.
It's just an informational glyph to let you see where the intersection point will be, this is displayed when Fillet R=0. Change the radius to add an arc and you will be able to see the arc before actually completing the command, allowing you to change the radius if desired. As far as I know, you cannot disable these.
In Options>Selection Tab>Selection Preview section, uncheck When a Command is Active. This will disable it.
