We have a corridor with a marked point and the code set style has a label attached to that point.
Everything works fine in the drawing where the corridor is located.
When we xref the corridor into the drawing where are sections views are located, that particular label doesn't show up.
all the styles in each drawing are the same.
Thanks.
Hi Mike,
Can you post your drawings for others to see?
