Valued Contributor
Postmaster_G
Message 1 of 13 (388 Views)
Mark items in alignment view to display in profile view...
388 Views, 12 Replies
12-20-2012 09:58 AM
Hello all! Civil 3D noob here... Though I have been using ACAD for about 5+ years, I have now begun using it for design by way of Civil 3D (about 3 months now).:robottongue:
Not knowing where to start makes it hard to know what to search for... so I appologize if this has been discussed previously.
I was wondering if after drawing an alignment, creating a profile, and profile view, is there a way I can mark items along the alignment so they could show up in the profile view.  I am laying out a pipeline and want to have the profile display a marker for items such as tees, elbows, reducers and other items.  The marker I would like to use will be something like the vertical style grade break markers.
Also on a side note, as each of these items will have a different name, is there a way that I can add these markers and then have each one with a unique name?
Thank you for your help!!!
troma
Message 2 of 13 (384 Views)
Re: Mark items in alignment view to display in profile view...
12-20-2012 10:30 AM in reply to: Postmaster_G
Look up the command for Project Objects to Profile View.
The commandline version is PROJECTOBJECTSTOPROF
It should also show up on the ribbon when you select your profile view.
There are a number of options for the style of the projction and its label, and the elevation for it.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Valued Contributor
Postmaster_G
Message 3 of 13 (376 Views)
12-20-2012 11:10 AM in reply to: troma
That seems to work pretty well.  What type of objects can I make that can each have its own name.
I created a simple block called SPOT.  I placed it on the alignment where a given tee is located.  Then I copied and pasted that block onto the next tee.  When I project them to the profile they get named SPOT-1 and SPOT-2.  On the label I am using the object name field and it displays the name.
It would seem that doing it this way would mean I would have to ceate 200+ blocks each with its own name?
Are there other types of autocad objects that I can insert repeatedly, each one having its own name.  As far as the plan view size I would want the object to be a very small spot.
Thank you :smileyhappy:
troma
Message 4 of 13 (374 Views)
12-20-2012 11:21 AM in reply to: Postmaster_G
Do you really need distinct names, or could you use the station to distinguish between them?
Another option is to make a unique layer for each.  You can label the source object layer instead of name.
Valued Contributor
Postmaster_G
Message 5 of 13 (368 Views)
12-20-2012 11:25 AM in reply to: troma
I guess you are right... I only need probably 5-10 names.  TEE, REDUCER, HIGH POINT... ETC.
Perhaps I can have them as layers or object-1 object-2 and so on.
*Pro
dgordon
Message 6 of 13 (365 Views)
12-20-2012 11:29 AM in reply to: Postmaster_G
why didn't you project the blocks you already has as tee, hydrant, bend, etc...?
Dan
Civil 3D 2013
Win 7 Pro x64
Intel Xeon 2.0GHz
12Gb Ram
ATI Firepro 4800
Dell T5500
www.preinnewhof.com
Valued Contributor
Postmaster_G
Message 7 of 13 (325 Views)
01-10-2013 03:26 PM in reply to: dgordon
The drawing is not a detailed drawing, it is an overall site plan.  Simple line work represents the piping.
This is what I ended up doing for now...
To label TEEs in the profile, I created a very small block (tiny circle with a tiny solid hatch) on its own layer called [4"x6"TEE].
Then I placed the block at each TEE location.
Next I would click project objects to profile.
Then I had to tediously select each block.
Then I change the label style text contents by adding in the "Source Layer"
Seems like this should be easier but it looks fine and didn't take too long.
Thanks for the advice!
troma
Message 8 of 13 (313 Views)
01-11-2013 07:04 AM in reply to: Postmaster_G
Should be easier....
Set up a label style with the right contents ahead of time.
When you go to project the block to profile view, make sure to select the right label.
If you click the column heading you can set the label for all of them at the same time.
troma
Message 9 of 13 (312 Views)
01-11-2013 07:07 AM in reply to: troma
You can go one step further and edit the command default settings to default to the desired marker style and label style every time you project items to profile view.
Valued Contributor
Postmaster_G
Message 10 of 13 (305 Views)
01-11-2013 09:14 AM in reply to: troma
Well I did get a label style setup after the first set of items had been projected.  So when the next set of items were projected, I was able to do as you said and just set them all.  The part I was hoping would be easier would be selecting all of the items between the time you click on project items to profile and when you hit enter and then select your options.  It would be nice if I could do some sort of quick select or select previous...
