Civil 3D Forum
Mapimport Header
14 REPLIES 14
Message 1 of 15
ksorsby
351 Views, 14 Replies
Mapimport Header
Morning,
I am trying to bring in some xyz text files using the mapimport command. The text files have a single line text header for 'easting, northing, elevation' or 'X,Y,Z' and there doesn't seem to be an option to 'ignore header' when I try to import the files, so it doesn't preview or import the files at all.
Any ideas how to import the points whilst ignoring the header?
The reason for this is that I am using the same point files that Mapinfo and TUFLOW uses and they need a header (as most GIS packages do) so I don't want to edit all the headers out and then edit it back in afterwards.
I appreciate this might be the wrong forum but C3D users are better than Map only users. 😉
Kevin
14 REPLIES 14
Message 2 of 15
rl_jackson
in reply to: ksorsby
create a copy of the file and remove the header, also you and put an exclamation (check format) in front and I believe it will ignore it. Either way you'll probably need a separate file.
Rick Jackson
Survey CAD Technician VI
Message 3 of 15
ksorsby
in reply to: rl_jackson
Hmmm. That's basically what I was trying to avoid, having a separate file identical in every way but without the header.
I'll try the exclamation mark thing though but don't know how Mapinfo will like it.
Autodesk really need to get the GIS capabilities up to scratch IMO.
Thanks anyway,
Kevin
Message 4 of 15
antoniovinci
Message 5 of 15
Murph_Map
@ksorsby wrote:
Morning,
Kevin
Says who? You know there's more than one way to bring in points from a txt file? Do you also know that Civil3D used have their own command to bring in points and harldy use the mapimport for it?
Murph
Supporting the troops daily.
Message 6 of 15
ksorsby
in reply to: Murph_Map
Antonio,
Thanks for this. Don't know how I missed this in my search, so apologies for that. I'll give this a go when I'm next on the job later today.
Murph,
Experience. 😉 .  I know you can import as cogo points but that's not that useful here as you can't add cogo points to a surface (why, I dont know!). So you have to faff about exploding which ones you need to vanilla cad points. Similarly, you can define a surface from a point file but I need the points at this stage, not a surface.
I tend to used mapimort because I use a lot of shapefiles, tabs, mid/mifs etc. but yes, it's probably not the best tool for straight point importing.
Cheers all,
Kevin
Message 7 of 15
Murph_Map
ksorsby wrote:
Murph,
What ever works for your needs is what I say. A lot of the map3d power users hang out over too.  🙂
Murph
Message 8 of 15
troma
@ksorsby wrote:
...you can't add cogo points to a surface ...
Kevin
Says who?  What type of surface are we talking about here?  I've built a C3D TIN surface from cogo points many many times.
Mark Green
Working on Civil 3D in Canada
Message 9 of 15
ksorsby
in reply to: troma
Me. A regular Civil 3D TIN surface.
Really? How? I certainly can't add them via Toospace/Surface/Definition/Points. Is there a ribbon command I'm missing?
Kevin
Message 10 of 15
mathewkol
Points are added to surfaces by point group. Make a point group, add your points to it, add the point group to the surface.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 11 of 15
ksorsby
in reply to: mathewkol
Thanks Matt - but that wasn't my original point. Plus Troma suggested that you can add Cogo points to a surface which AFAIK you can't.
My original query was bringing points in via mapimport and ignoring the header. I can easily bring in points as point files in a surface but that isn't what I need. I can also bring them in as Cogo points, but Cogo points aren't much use to me on this type of project.
Thanks though.
Kevin
Message 12 of 15
mathewkol
Sorry for wasting your time answering your thoughts about adding cogo points to a surface, which you can, just not individually.
Matt Kolberg
Message 13 of 15
ksorsby
Please don't be sensitive, it's really not worth it.
I suspect we're all talking crossed wires now in this thread so I'd be happy if someone locks or deletes it.
Cheers,
Kevin
Message 14 of 15
troma
Sorry I'm late to reply to this, and sorry the conversation has gone sideways for you. Matt made my point for me, so there's no need for me to elaborate.
Mark Green
Message 15 of 15
ksorsby
in reply to: troma
It's really no big. I think I have what I need to know now anyway so I can figure a workaround.
Cheers all,
Kevin
Rail Community
