I have custom object tables added to civil3d pipework objects so that I can export custum info for BIM purposes.
When I use the ExportCivilobjectsToSdf commandI get the usual entries into the SDF object tables but the attached object table & data do not pass over.
When I run Mapexport no objects are exported?
Is there a way apart from creating a join to export this data?
Civil3d 2013 / SP1, S3d 2014 (unused)
@Anonymous wrote:I have custom object tables added to civil3d pipework objects so that I can export custum info for BIM purposes.
Nope, Civilexort doesn't see the Map OD tables and the mapexport can't read the C3D objects.
neilyj (No connection with Autodesk other than using the products in the real world)
Well, I am not bearing a grudge due to incompatibility.
I have moved on and created a code to extract all the pipe / structure information (needs a bit of tweaking), explode the objects and add the object data tables so I can pass the information correctly to Map.
The goal here is to also get this information into Revit but I think I may have bitten off a huge chunk that I can't swallow there.
Thanks.
