mikehathaway2942
Message 1 of 34 (1,910 Views)
MapCheck Analysis - Legal Description Closure
1910 Views, 33 Replies
02-10-2012 01:58 PM
Civil3d 2012
We are looking at the best practice for checking closures on over 100 legal description, each requires a closure report.  I am familiar with the Mapcheck routine that requires all lines and curves to be labeled but find this to be an excessive amount of work.  I mean why would we want to label the lines when there is no need to...besides the software need to have it.  In LDD we cogo up a legal description, make it a pline and go through the analsis/figure menu and voila' a mapcheck report is created.  In civil3d we seem to be forced to label the lines first and then you have to manually pick each of them.  This is excessive and overly cumbersome.
We have even tried toggling the command line window in the map check analysis and hand entering the bearing and distance for each side.  While this works the brg and distance input is different i.e. you have to type N45-45-23 W then mouse down to the distance input and enter the distance.  We quickly canned that method due to the data entry procedure.
Parcels won't work because nothing ever created based on a metes and bounds legal, with the excpetion of a square or rectangle, will close flat.
There has to be a better way!
Jeff_M
Message 2 of 34 (1,909 Views)
Re: MapCheck Analysis - Legal Description Closure
02-10-2012 02:02 PM in reply to: mikehathaway2942
This is precisely why we added SPPARCELINVERSE to the SincpacC3D.
mikehathaway2942
Message 3 of 34 (1,906 Views)
02-10-2012 02:09 PM in reply to: Jeff_M
Well....once we can fit your software into our budget we'll definitely be picking it up.  Until then....
Distinguished Mentor
JeffPaulsen
Message 4 of 34 (1,895 Views)
02-10-2012 02:53 PM in reply to: mikehathaway2942
If they are defined as parcels you can use the Parcel Map Check Report.
Jeff Paulsen
Civil 3D 2012 SP3 | Win 7 64-bit SP1
Xeon E5-1620 @ 3.60GHz, 16GB Ram | NVidia Quadro 600
mikehathaway2942
Message 5 of 34 (1,893 Views)
02-10-2012 03:02 PM in reply to: JeffPaulsen
Thanks Jeff, but parcels must close. (Unless you know some way around that)  All legal descriptions have a mis-closure, therefore parcels will not work.
JeffPaulsen
Message 6 of 34 (1,890 Views)
02-10-2012 03:07 PM in reply to: mikehathaway2942
Yeah your right; that will not work for legal descriptions.
Jeff Paulsen
Employee
peterfunkautodesk
Message 7 of 34 (1,882 Views)
02-10-2012 04:00 PM in reply to: mikehathaway2942
If the lots are defined as polylines, have you tried the COGOEditor in Civil 3D? One of the features is to load a traverse from a polyline. If you define the POB and POC at the start of the polyline and run the analysis button you should get your closeure report. If you want to balance the polyline you can do that as well.
It is also a nice tool for adding the lots from the legals.
Cheers,
Peter Funk
Peter Funk
mikehathaway2942
Message 8 of 34 (1,880 Views)
02-10-2012 04:07 PM in reply to: peterfunkautodesk
Yes, Peter we have tried that.  On my CPU it works ok but on the other CPU in the office the error of closure is always infinite and 0.0000 even if the error is 0.02 or 0.0049.  Must be a setting somewhere for that? Any ideas?
Valued Mentor
bcsurvey
Message 9 of 34 (1,546 Views)
12-03-2012 07:09 AM in reply to: mikehathaway2942
I'm casting my line into a different post, hoping for a bite.  I apologize for the redundancy.
Was this problem ever resolved?  I too am searching for the best way to generate closure reports and/or traverse adjustments.  So far, I've found that the adjustment through mapcheck (right click on mapcheck item in input view, choose adjust) gives the best adjustment (i.e. it actually shows all necessary data).  I can't get the cogo editor adjustment report to show any x, y, or z deltas as anything but 0.0000, but I'd like the report output style it displays - it's easy for those unfamiliar with adjustment data to understand.   So specifically:
1) Has anyone come across (or perhaps designed) a C3D-style report for a mapcheck output (not parcel mapcheck) so that I don't have to paste into Word and customize text size and font?
2) What's the trick for showing adjustment data through  the cogo editor?
Thanks!
Civil 3D 2014
Windows 7 Professional SP1
Dell Precision T1700
(i7 @ 3.40 GHz)
8GB RAM
Nvidia Quadro K600
Employee
peterfunkautodesk
Message 10 of 34 (1,542 Views)
12-03-2012 07:37 AM in reply to: bcsurvey
Save and post a traverse from the COGO editor and we'll take a look at it.
Peter Funk
Peter Funk
