AM I wrong when I say MAPBOUNDARY and MAPTRIM are not working in C3D 2015 from the workspace Planning and Analyse?
Also typing it on the commandline is not working.
Solved by neilyj666. Go to Solution.
Could be related to a missing support path; see http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Map-2015-problems/m-p/4931976#M245659
Service pack 1 has been released and this issue has still not been resolved. I just installed the service pack on a computer that did not have the support path manually added and it did not fix this issue.
Bit of a pain for deployments where you need MAPTRIM to work!
Found Solution here
Hi Darren,
This is not as designed...
For the time being I wrote a technical solution to describe the issue/solution.
Apology for the inconvenience.
Kind Regards,
Nicolas
