Civil 3D Forum
map menu missing
4 REPLIES 4
797 Views, 4 Replies
map menu missing
i am working civil 3d 2006 , now i am facing a problem
i am missing MAP menu(pulldown) in my workspace. i try to do in CUI but i could not getting map menu
if anybody knows about this error please help me
Sa
4 REPLIES 4
Civil3DReminders_com
The screen shot is from 2008, but the location should be similar, make sure the partial CUI file for map is loaded.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Sinc
I don't remember which Map CUI came with 2006. It's called MAPCLASSIC now, but I think it was ACMAP in 2006.
But if you alread have that CUI loaded as a Partial CUI, then I'm guessing you're having the usual problem. This part of the CUI is not very well-designed, and is a bit tricky.
In order to add a menu to a workspace, you must click on the workspace in the upper-left quadrant of the CUI. Once you select a Workspace, a "Customize Workspace" button will appear in the upper-right quadrant of the CUI. Click on this button. Now you can find the Map menu in the upper left-hand quadrant of the CUI and click on the little checkbox next to it to add it to your workspace.
Sinc
Thanking you very much for your valuable information, it is working now
jdekoster
In Civil 2019 the map menu is still in mapclasic.cuix
Rail Community
