Solved by Discussion_Admin. Go to Solution.
OK?!?! Without changing anything. Suddenly it works. Unless Changes that I made have now for some reasin taken effect.
Sorry to take so long on resolving this Issue. It appears that the reason my Forums suddenly worked was that I disconnected from the company server. I had IT remove the ADDTHIS.com Blocking form the Filter and "Bob's you uncle" I'm back in business.
Thanks to discussion Admin Modorator for the the tip.
I've having this problem with the FDO data connect, and a lot of aerial images but only wanting to select a select few, but the ordering of the images makes it near on impossilble to find the ones I want.
I was wondering if anybody found an answer to sorting this data?
Thanks.
