Solved by Discussion_Admin. Go to Solution.
I don't see your image. If you right-click in a "white" area where this is no connection, you can choose Sort Content.
M,
You can put a PNG in the body of your message thusly:
You can also attach a PNG or JPG or DWG by clicking here:
Dave
Dave Stoll
Las Vegas, Nevada
M,
Looks like one of the PNG's I inserted in the body of my message didn't stay inserted. Here's try number 2:
Dave
Dave Stoll
Las Vegas, Nevada
Mark,
I looked last night tring to find the rhyme and reason as to how they get sorted and can only "GUESS" it's from the FDO provider.
As for the missing toolbar what browser are you using in the forums?
@mconway wrote:
I don't get this fancy toolbar in my BODY window
Ok a few things to try if using IE please make sure you are not in "compatibility" mode as it is not supported.
Also make sure you are not blocking scripts from Autodesk or Addthis.com they are need for all features to work.
also please make sure you are using the latest releases of the supported browsers below (with JavaScript enabled):
Chrome
Firefox
Internet Explorer 8+
Safari
For mobile device browsing the latest popular mobile operating systems and devices with their default browsers (with JavaScript enabled):
iOS with Safari
Android with Android browser
Opera Mini
Blackberry Browser
Discussion_Admin
Are you using the html tabor the rich text tab in the body area?
In firefox, for me, the rich text tab has the toolbar and html does not.
@mconway wrote:
It doesn't matter which tab I use. or which Browser. Firefox, Chrome & IE all behave the same. I have a bad setting on my PC or on this site. I don't get the fancy toolbar I can not Attach I can not Quote My message formatting also does not stay when I click POST.
This behavor is the result of Java scripts being blocked. Scripts from autodesk.com and addthis.com must be unblocked for the community to work properly please see my post above.
Discussion_Admin
If trying to post from work I would suggest checking with your IT dept some have scripts from ADDTHIS.com blocked.
Discussion_Admin
